Link G4+ Group Buy
We are running a group buy on Link G4+ Plug-in fitted with Boost control and Mapping. For the Group Buy to go ahead we will need a minimum of 5 people and once we have 5 or more people we will take deposits and order the ecu`s and we can then book you in for fitting. The group buy covers the RB and SR plug-in so if your running a SR20 it will be the same price.
The Group Buy Includes the following :-
Link G4+ Plug-in Ecu
High-Speed Air Temp Sensor with Alloy Boss
Boost Control Valve
AFM Delete Pipe
Fitting of ECU into your original ecu case, welding airtemp boss and wiring of air temp and boost control valve.
Mapping of vehicle and setup of boost control.
Dyno Printouts of Power and Torque
Pricing does not include any adjustments to cam timing if you have adjustable cam pulleys and will be charged ontop depending on time taken. The above package includes boost control so if you already have a controller you will no longer require this as the link will do this and can still have different boost levels.
If we can get 5 or more the price all in is £1527.60.
The above is a Package so please do not ask how much without this or that as we can only supply it as listed above.
If you would like to be on the group buy please put your name bellow and we will get a list going.
Boost Control Valve
AFM Delete Pipe
