right then ppl, i have founf the feed and thats all sorted, i have found the mark where the return should be put as i have found out its not a case of undoing the bolt like the oil feed is. Is there another way of returning the oil back to the sump without drilling the block, could i drill into the sump? I know that the oil has to drain freely and quickly otherwise the oil will just sit in the turbo....Any ideas ppl?
thanks
