1 - 3 of 3 Posts
need help with locks i geuss the ignition key does not work with the locks and that is the only key that i have what do i need to do?
Forum Gypo
They have probably been changed at some time, the ignition I would guess.
Try the "parts for sale section" somebody will probably have a second hand set of door locks they will sell you or if your lucky, maybe the whole set, ignition aswell. If that fails, try the "parts wanted section" somebody will have a set somewhere.
Thats your best bet I would say!
Maybe you could try the German, "Skyline Forum", somebodys bound to have a set lying about and you could save yourself some money on the postage:
Member
hi pal, one problem is corrosion with the wafers inside the barrels on the door locks. if your lucky a good drenching in WD40 will get them working.
failing that the door locks will need stripping and cleaning.
dont use anything thicker than WD40 cos it can easily clog up the barrel
1 - 3 of 3 Posts
