· Registered
Hey,
Id like to know if you can supply longer wheels studs for the r33 gtst.
For the Wheelhub.
I dunno about where to get ones.
The diameter of the part which is pressed into the hub is different between rear and fron hub.
Perhaps you can supply longer or oem size wheel studs.
Would be nice to get answer.
Best regards Georg
· Seasoned Member
Hey,
For the Wheelhub.
Best regards Georg
Yes we can,
we have 66mm studs in stock - depending on how many you need we can do them for around £1.50+vat each
thanks chris
· Registered
Yes we can,
thanks chris
Do you have 10 rears to fit a R33 GTS-T? Think they're M12x1.25 with a 12mm spline with 34 blades?
Steve
· Registered
R33 GTsT Rear Studs
Chris,
I have Erglanz 3 Spoke Wheels on my R33
Previous owner has knackered the wheel nuts
If I have to resort to drilling the studs out can you supply the rear replacement Studs
Not sure if they are standard length or not but there is plenty of room in the wheel to accept longer studs pic below
Ad
