I was unfortunate enough that when I first got my 32 it had the front & rear single-piston calipers.
Then was lucky enough to pick up a 33 GTST for next to nothing so swapped brake calipers (& rotors) over.
They stopped the car fine but even when properly bled the pedal felt like it didnt start actually doing anything until it was about halfway down.
I figured the 33 m/c probably had a bigger bore size & even if it didnt, the 32 m/c has a weird design with fluid going to the end of the bore then doing a u-turn before getting pushed down the line, so figured even if same bore that the design was giving me the low pedal feeling.
So recently when I fitted the motor & gearbox from the 33 into my 32 I also swapped master cylinders, modifying a few lines along the way.
Also swapped boosters as my 32 m/c had been leaking all over (& into?) my old one.
However, now, even with the R33 master cylinder & booster that was originally matched to the calipers I have, I get the same low pedal feel.
I am going to re-bleed the brakes but dont think it is going to make much difference. Very confident there is no air in them...
Does anyone have any other suggestions or has anyone had this same problem?
Thoughts & advice would be great.
Cheers,
Brett
Cheers,
Brett
