1 - 10 of 10 Posts
Ring lands gone, pistons cracked or a hole in the pistons. All of them readings are below what they should be, not just the 3 obvious ones. Once and if you get it repaired or replace you need to diagnose the cause of so many failures or it may happen to your next engine.
G
likely ring lands are broken
RB25 engine only has a couple of Achiles heals
1: Piston ringlands
2: Exhaust manifold studs
But hey its not the end of the world mate as they are quite cheap now for a full engine on Ebay etc ....be thankfull its not an RB26
Good luck
erm how regular is it that these go , as just took head off , & dont want to build back up then 50 miles the rings play up , although all looks like its behaving its self in there
G
Why did you tke the head off?
Do or get done a compression test when its all back together.
1 - 10 of 10 Posts
