Hello,
My car seems to have developed a bit of a misfire if I rev it hard in 1st or neutral. i think its a missfire anyway - what happens is at about 4-5krpm the engine pauses and sort of backfires a bit then carries on. sounds like as if you where bouncing it off the limiter but obviously its only at 5krpm.
Any ideas of things that I can check?
Will this damage the engine? If I take it easy in 1st I can rev it all the way with no missfire.
Splitfires and NGK spark plugs where added at server 2000 miles ago.
Any advice appreciated
:cheers::cheers:
:cheers::cheers:
