Hi everyone! I have recently bought an r33 gtst 1995 with 100k km on the clock and a few mods, front mount, air filter, full straigjht through system. just recently when i take her above 4500rpm it starts popping and back firing, was wondeing if anyone had any helpful suggestions on the prob? it also idles very lumpy and i thought maybe it hadnt been mapped to run on uk fuel, as it is a fairly recent import? thanks alot!
i had the same problem on mine
check the plugs and coils 1st, if these are ok you will need to sort out the fueling maybe get a safc as a fairly cheap option:bigthumb:
..and check the AFM, there's a whole thread or two on this!
Aitch
Hey mate, I had the exact same problem, I changed the plugs and reconditioned the coilpacks...use the search button as there is a thread on how to do this, really easy and should fix your common problem. Or if you dont mind spending a bit of money you could buy the Splitfire coilpacks. Cheers
could be lots of things, including any of the things already mentioned. I used to have a similar problem after making the mistake of cleaning the engine bay without realising the spray contained silicon. sent the boost solonoid haywire..
i had to regap mine when it missfired. check and make sure they are at .8 mm
