1 - 11 of 11 Posts
Hello people..
Looking at purchasing the above... tis a 2.8 turbo diesel model.. M reg, £2225..
Anyone had any experience of these? Anything to look out for etc??
Never had a 4x4 in my life so not sure where to start!
(i know it aint a skyline but you guys are the most knowledgable people i know!)
cheers,
:D :D
We had a LWB Shogun. Brilliant 4x4 and really reliable. But I will say that a mechanic friend of mine says that the Pajero's can have headgasket problems so watch out with buying one. The only other known problem I have heard about is the gearboxs on the Shoguns but I never had any problems with mine but it had had very light usage when I bought it back in 2000 and it was an M plate 2.8td.
Allkiller No Filler
Mine was the same as your looking at....Faultless car.
only problem i ever had with it was oil cooler at front sprung a leak where the pipe passes thru the slam panel. Rubbing
easily fixed.
Good work horse
Fuel consumption is worse than the Skyline
O
Guest
Ive had one as well, the headgaskit is only a problem in the older 2.5 version not the 2.8, the 2.8 is a very good engine though a little bit thirsty. woo hoo.
No cam belt on the 2.8 either - is its a manual - watch out for jumping out of 4th gear - and ive had a ring gear go on mine before.
i am thinking of buying one too? ( something to tow the skyline to track days ;) )
but i also thought about a delica? its a floorpan/chassis of a shogun but much more roomier!
D
Guest
I use a auto SWB 2.8 turbo diesel Pajero as a recovery vehicle at work, faultless so far in over 5 years of abuse :D
One problem I had with my pajero is some little weed stole the bullbars. Make sure everything is welded on:eek: Other than that a sound car, In four years my own has needed a glowplug relay two headlamps and i've just doen the brakes and exhaust. The gearbox is a bit notchy when cold but thats what you get for not checking the oil since ye bought it.
1 - 11 of 11 Posts
