Keep twins. You can do that for a lot less, keep the stock twins, get them rebuilt later, run your GTR loom and ECU, get it stage one chipped first, and you will be set. If you try all that other **** you are actually looking for more money and why when you can use the above stated. You should run the wiring to the GTR for the engine to properly do everything it needs. That's my suggestion.
