1 - 11 of 11 Posts
ok guys here goes, my skyline has failed its mot ,the only worrying thing for me is the emissions . if i clean the air control valve thing (the bit that contains the idle screw) as mentioned in other posts ,do you think it will make a difference? the guy at the garage thought it was a possibility?? and i have had the idle /nearly stalling problems mentioned , but will it make a difference to the emissions?
thanks-rich
What years the car?
what exactly did it fail on? co2,lambda or hydrocarbons and what were the readings?
looking at the print off(test was based on skyline model code r33: all versions?) it failed on all 3,heres the result:
fast idle test:
co 8.96%vol
hc 244ppm
lambda 0.76
2nd fast idle test:
co 8.98%
hc 718ppm
lamda 0.74
natural idle test:
co 9.35%
i dont really know what to replace if anything? cat maybe or lambda sensor thingy? i was hoping to get the emissions down by cleaning the air control valve with carb cleaner, but seeing as im not really technically minded , im not sure if it would make any difference.:confused: it passed last year but at a different mot station.
8.9% & 9.5% CO????? that cant be right? if it is its going to take more than giving something a clean im guessing!
I get under 0.5% WITHOUT a cat on.
yeah i thought that,i just found some relevant posts on the emissions subject and im confidant-ish that i need a new lambda sensor. must be a nice hole in the ozone from my place to work!:eek:
this might seem like a silly question is the exhaust solid
only ask as mine recently faild emitions but had a hole in backbox put new exhaust on with no middle box and past easily.
also is the cat intackt and not had internals removed
Discussion Starter #11
afaik the cat is intact,as for the exhaust i have a stainless one going on next tuesday although it didnt fail on the exhaust. shes off the road for now tho:disappointed:
1 - 11 of 11 Posts
