wat would be causing my r34 GTST skyline to have no boost, keeps losing complete power, sounds like a rumbling V8 not a spooling turbo Air leaks I can hear, that I couldn't before... Misfiring as well and its Surging and cutting out to wat would b the cause/issue that I have
Process of elimination I'm afraid could be down to quite a few issues from failed/broken turbo to fuel/timing problems or bad rings ring lands, I would start by running a compression and leak down test then check for ECU error codes and go from there.
