1 - 20 of 28 Posts
just had a look! thats brill mate and with loads of helpfull pics :D we like pics.
I want to fit the same kit for the same reason do you mind telling me how much you paid for the full kit mate?
Rob, could you give us a ring on 0845 86 92 555 ASAP please?
It looks like the brackets aren't fitted right in your pictures and that needs resolving sharpish as the car may be dangerous to drive like that :(
I can post some picture to explain if that helps?
righto, basically the brackets are made so they held onto the subframe with 2 bolts.
One bolt attaches the bracket to the original mounting point for the HICAS rack.
The other, longer bolt that holds the balljoint into the bracket also goes through an existing hole in the subframe and holds the bracket secure. If you only use 1 bolt to hold the bracket on, it will flap about and dynamically change your alignment, which is never ideal....
I've highlighted the bolt and the hole it should have gone through on these 2 pics of yours here:
You can see how the brackets are supposed to sit in this pic here:
Hope that helps, just let us know if you're not sure still.
cheers,
James :)
T
Guest
Yep I read it but couldnt comment or commend you there. So er....Well done? :D
One more thing: Does this require re-alignment of the wheels?
1 - 20 of 28 Posts
