Hey guys my r33 de+t was making 280rwkw and the ringlands broke my question is i wanna get a forged Piston kit i found one acl race series they are 0.5mm oversize do i need to machine my block out and also what headgasket do i run with it? Thanks
Sent from my SM-G930F using Tapatalk
If you need over size pistons then yes you will need the block machined to fit the bigger pistons.
I took my block to a engine specialist and they measured the bore and advised what I needed.
I spoke to conceptua tuning and got everything I needed including the head gasket which they advised on.
