hey guy i was just washing my car then i will not start... its just not kicking over for some reson what should i do? i have a small bonet scoop on my r33 and it got a lil wet thats it ?
big ginger one
when you turn the key is nothing happening are all the lights on the dash coming on ?
what alarm have you got installed
Is it a spec 1 R33? If so, check the connections on the coil pack ignition amplifier. With that unplugged the engine will turn but not fire up so it could be a good starting point if yours is doing the same.
Dorset/Wilts Area Rep
You need to check:-
Ignition Amp fro dampness : its bolted to the back of the engine.
Check that theres not a huge amount of water in the coil pack area.
Check the CAM angle sensor located at the front of the engine attached to the exhaust cam.
I'd even check the injector plugs, long shot but worth an inspection.
Let us know how you get on.
