First off wondering if anybody has an extra coil pack for rb20det their willing to sell or just don't need? Second I have a massive exhaust leak near the turbo I have tightened everything but no change so I think I need to find somewhere I can get ahold off some new gaskets ASAP. Thanks in advance for any help
Before you go buying gaskets its best to suss out where the leak is coming from!
Usually the gasket between the head and manifold lets go..... due to loose/missing manifold nuts. They work their way loose on the RB and if you remove the manifold you will probably snap some studs - There is plenty of info about how to do/fix that buried in the forums!
The other gasket to go is between the manifold and turbo.
It may be something else, but those are the common things
Honestly man, I wouldn't bother messing about with single coil packs trying to fix a miss. ALL standard coilpacks are going to be 'high risk'..... the one you buy may die tomorrow, they are all old and well used. Its best to just buy 6 new coil packs to save any hassles later
u must be the one who bought intfreaks r32 (black, without exhaust and fmic)!!!?!?? i think u can use the rb25 spec1 coilpacks too. i only have some for a spec2, so they don´t fit.
No I got this one i bought outta japan myself but intfreaks skyline i put back together about a month ago now.
