1 - 11 of 11 Posts
Ok, this facility was suggested a little while back. It allows you to select certain forums you do not want to appear in the New Posts search. For instance you might not want the Posts in the Lounge and Nitey's Room to appear in your New Posts search.
To use the facility you need to go to your user options (Quick Links->User Options) and at the bottom you will see a list of forums you can select to remove from the New Posts search.
Hope this helps some of you filter the unwanted content.
Lenny
i would like it not to tell me when i log in that im most active in newbies.
could we have that function for favorite room.
i do like welcoming newbies.
Presumably I can set it to filter out everything except Nitey and Shadow's threads then? :)
Seriously - good work Lenny - top idea. Will mean I can read 10 pages rather than 30 when I come back form being away :cheers:
1 - 11 of 11 Posts
