1 - 2 of 2 Posts
Hi, I am looking at buying an R32 already in the US by one of two good dealers, the question is is it better to buy a more modded gtr or no?
The choices Im looking at is
#1
Purple R32 coming in with the following mods
R34 N1 Turbos
Maybe Built Motor
AM Exhaust Manifolds
HKS Turbo Elbows
Hks Equal Length Downpipes
Titanium Catback Exhaust
AM Catch Can
HKS Oil Filter Relocation Kit
AM Oil Cooler
AM Power Steering Cooler
HKS IC Piping
AM FMIC
Custom Suction Kit
Tabata Aluminum Radiator
Samco Radiator Hoses
HKS Twin Power Ignition System
HKS Air Filters
Greddy Fuel Rail
Nismo 555cc Fuel Injectors
Sard Surge Tank
Twin Disc Clutch
Nismo LSD
AM Tension Rod Brace
AM Tension Rods
Am Front Upper Control Arm
LMR Sway Bars
Zeal Coilovers with Swift Springs
Nismo Rear Lower Control Arms
Nismo Traction Arms
AM Rear Upper Control Arms
Hicas Delete Bar
Aluminum Subframe Collars
Endless BBK with 2-Piece Rotors
Cusco 3-Point Rear Strut Tower Bar *Rare*
Front Strut Tower Bar
Endless Racing Front Lip
Endless Racing Vented Carbon Fiber Hood
Widebody Vented Front Fenders
Custom Widened Rear Fenders
N1 Side Skirts
N1 Style Rear Spoiler
Bride Zeta 2 Driver’s Seat
MOMO Steering wheel
AM Shift Knob
13 Point Cusco Roll Cage
HKS EVC 6 Boost Controller
Mine’s 320kph Gauge Cluster
Greddy Boost Gauge
Greddy Water Temp Gauge
Greddy Oil Pressure Gauge
Greddy Oil Temp Gauge
Greddy Fuel Pressure Gauge
Greddy Ext Gauge
Battery Relocation to Trunk
Choice #2
1990 Nissan Skyline GT-R R32
Red(AH3)
57,036km/35,647miles (TMU)
MODS LIST
Nismo 260km Cluster
Bronze Works XD9 Wheels
NPG Coilovers
Aftermarket Catback Exhaust
Aftermarket Test Pipe
MAINTENANCE & SERVICE
New Spark Plugs
New Battery
New Air Filter
New A/C Vent (Center)
New Clutch Booster
New Fan Belt x 3
New Front Lower Arm Ball Joint x 4
New Front Tie Rod End (L&R)
New Rear HICAS Tie Rod & Socket Rod (L&R)
New Rear HICAS Ball Joint (L&R)
New Wheel Lug Not x 20
Engine Oil & Filter
MT Oil
Transfer Oil
Diff Oil Front & Rear
Engine Coolant
Brake Fluid
Replace Brake Pads (F&R)
Replace Axle shaft boot (Front LH:Outter)
Wheel Alignment
West Sussex Area Rep
Choice is yours.
A non modded will probably hold it's value better, and it'll be a platform for you to do your own thing if wanted.
Modded, someone has spent time and money making it better. Saves you money in the long run if that's the road you want to take :)
1 - 2 of 2 Posts
