1 - 20 of 22 Posts
East Ireland Area Rep
Nissan OEM & Nismo Part Numbers - R33 GTST
Admin / Mods - please sticky this thread please
Let's start getting a reference thread for all the common Nissan Skyline R33 GTST OEM / Nismo part numbers that you generally need on a R33 GTST.
Some are really hard to find so lets make it easy & all in one place!
Only post genuine Nissan OEM or Nismo part numbers please.
Probably no harm to get other threads together for other versions.
*Disclaimer* Check the part numbers yourself, this is only a guide. Some of these part numbers may have been superseeded.
Here is what I have so far(will keep adding to it as I find more) but feel free to add your own lists
Updated: 08/04/2018
Nissan OEM VCT Solenoid: 23796-97E01 / 13025-75T05
Nissan OEM VCT Sprocket: 13025-0V000
Nissan OEM Crank Angle Sensor(Mitshi Version): 23731-02U11
Nissan OEM Z32 AFM & Pigtail: 22680-30P00
Nissan OEM Brake Master Cylinder(BM44, 15/16") Tokico with ABS: 46010-75T02
Nissan OEM Fuel Pump Relay: 25230-79981
Nissan OEM Coolant Temp Sensor: 22630-44B20
Nismo R33 Brake Hose Set: 46200-RSR30
Nissan OEM Radiator Cooling Fan: 21060-5L300
Nismo R33/R34 2WD HICAS Engine & Gearbox Mounts: 11220-RSR40(x2) & 11320-RSR40
Nismo R33 Short Shifter: 32839-RN580
Nismo R33 Mat Set: 74902-RNR35
Nissan OEM Tensioner Belt Pulley: AY460-NS010
Nissan OEM Idler Pulley Assembly: AY660-NS001
Nissan OEM Oil Filter: 15208
NIssan OEM Blow Off Valve Gasket: 14489-04U00
Nissan OEM Water Pump: 21010-21U25
Nissan OEM Oil Pump: 15010
Nissan OEM N1 Water Pump: 21010-24U27
Nissan OEM Trim Clip: 01553-09321
Nissan OEM Fuel Filter: 16400-41B1A / 16400-Q0805(Z32 300zx upgrade - higher flow)
Nissan OEM Front Brake Discs: 40206-21U00 x2
Nissan OEM Oxygen Sensor: 22690-83T10
Nissan OEM Knock Sensor: 22060-56S10 x2
Nissan OEM Propshaft Front Seal: 38189-N3111
Nissan OEM Propshaft Rear Seal: 38189-Y0810
Nissan OEM Valve Cover Gasket Set: 13270-58S01 + 13270-58S11
Nissan OEM Turbo Inlet Gasket: 14415-4P200
Nissan OEM Piston Rings STD (86mm): 12033-21U10
Nissan OEM Center Exhaust Hanger (Square): 20610-52F00
Nissan OEM Front Caliper Rebuild Set: 41120-30P25
Nissan OEM Rear Inner CV Boot: 39741-03P28
Nissan OEM OEM PCV Rubber Grommet: 11812-41B00
Nissan OEM OEM PCV Valve: 11810-21U00
Nissan OEM Front Brake Hose Washer/Gasket: 46237-A4600 x4
Nissan OEM Brake Master Cylinder Repair Set (With ABS): 46011-70T26
Nissan OEM Brake Master Cylinder Repair Set (Without ABS): 46011-75T26
Nissan OEM Clutch Master Cylinder Repair Set: 30611-21U25
Nissan OEM Clutch Master Cylinder: 30610-21U00
Nissan OEM Rear Camber Bolt Kit: 55226-35F11 x2
Nissan OEM Water Temperature Sender: 25080-89907
Nissan OEM Water Temperature Sensor: 22630-44B20
Nissan OEM Oil Sump Gasket: 11121-42L00
Nissan OEM Front Windscreen Wipers Cover Rubber Seal: 66830-15U00
Nissan OEM PAS Pump Seal Kit: 49128-71L25
Nissan OEM Brake Master Servo Gasket: D7212-50Y00
Nissan OEM Gearbox Rear Oil Seal: 32136-01G10
Nissan OEM Crank Pulley Bolt: 12309-42L00
Nissan OEM Crank Sprocket: 13021-42L11
Nissan OEM Front Crank Oil Seal: 13510-19V00
Nissan OEM Timing Belt: AY440-NS014
Nissan OEM Timing Belt Front Guide Plate: 13023-42L00
Nissan OEM Crank Rear Sprocket Plate: 13022-42L00
Nissan OEM N1 Oil Pump: 15010-24U01
Nissan OEM Oil Pump Gasket: 15066-71L00
Nissan OEM Complete Engine Gasket Kit: 10101-17U29
Nissan OEM Rear Hub Bolt: 43222-50J00
Nissan OEM Rear Differential Cover Gasket: 38320-40F02
Nissan OEM A/C Pulley: 11925-42L06
Nissan OEM Gearbox Drain Plug: 32103-U840A
Nissan OEM Front Rubber Hood Bumper: 90878-2L700 x2
Nissan OEM Front Right Door Power Window Switch Trim: 80960-22U10
Nissan OEM Throttle Position Sensor (For S1): 22620-02U11
Nissan OEM Rear Brake Shoes: AY360-NS048
Nissan OEM Front Handbrake Cable: 36402-70T05
Nissan OEM Rear Right Handbrake Cable: 36530-15U10
Nissan OEM Rear Left Handbrake Cable: 36531-15U10
Nissan OEM Rear Axle / Dif Seal: 38342-N3100 x2
Nissan OEM Rear Dif Shim 0.80mm: 38424-40F60
Nissan OEM Rear Dif Shim 0.85mm: 38424-40F62
Nissan OEM Rear Dif Shim 0.90mm: 38424-40F63
Nissan OEM Rear Dif Shim 1.01mm: 38424-40F67
Nissan OEM Rear Dif Shim 1.05mm: 38424-40F68
Nissan OEM Rear Dif Shim 1.10mm: 38424-40F70
Nissan OEM Rear Dif Shim 1.20mm: 38424-40F73
Nissan OEM Rear Dif Shim 1.30mm: 38424-40F76
Nissan OEM Rear Dif Shim 1.40mm: 38424-40F80
Nissan OEM Rear Dif Shim 1.49mm: 38424-40F83
Nissan OEM Propshaft Center Bearing: 37521-41L85
Nissan OEM Reverse Light Switch: 32005-21U00
Nissan OEM Clutch Slave Cylinder: 30620-21U01
Nissan OEM Speed Sensor: 25010-21U00
Nissan OEM HICAS Ball Joint: 55154-0P800 x2
Nissan OEM HICAS CV Boot: 48203-79T25 x2
Nissan OEM HICAS Inner Tie Rod: 48521-79T00 x2
Nissan OEM HICAS Tie Rod End: 55725-0C800 x2
Nissan OEM Rear Camber Arm Eccentric Washer: 55227-35F10 x2
Nissan OEM Brake Disc Cover Rear Left + Right: 44030-21U10 + 44020-21U10
Nissan OEM Front Brake Pad: AY040-NS037
Nissan OEM Rear Brake Pad: AY060-NS003
Nissan OEM Rear Inner + Outer Left CV Boot: 39241-03P27 + 39241-73L27
Nissan OEM Rear Inner + Outer Right CV Boot: 39741-03P28 + 39241-73L26
Nissan OEM Rear Brake Caliper Seal Kit: 44120-43P26
Nissan OEM Rear Brake Discs: 43206-20U02 x2
Nissan OEM CAS Gasket: 13568-58S00
Nissan OEM Turbo Elbow Gasket: 14445-V2700
Nissan OEM Throttle Body Gasket: 16175-75T01
Nissan OEM Turbo Gasket Kit: 14401-21U25
Nissan OEM STD Intake Valve: 13201-08U02 x12
Nissan OEM STD Exhaust Valve: 13202-081 x12
Nissan OEM PAS V-Belt: AY140-30845 (aftermarket: 3PK845)
Nissan OEM Alternator V-Belt: AY140-40850 (aftermarket: 4PK850)
Nissan OEM A/C V-Belt: AY140-40910 (aftermarket: 4PK910)
Nissan OEM Timing Belt: 13028-20P25
Nissan OEM Crank Rear Seal 8.5mm / 10mm: 12279-5L310 / 12279-85G00
Nissan OEM Inner Tie Rod: 48521-15U26 x2
Nissan OEM Tie Rod End: 48520-15U25 x2
Nissan OEM Steering Rack CV Boot: 48203-91P85 x2
Nissan OEM Power Steering Hose (from bottle - short hose): 49725-21U20
Nissan OEM Power Steering Hose (from bottle - long hose): 49717-21U00
Nissan OEM Brake Master Cylinder (non ABS): 46010-75T01
Nissan OEM Servo Booster Hose (has one way valve inside): 47474-17U00
Nissan OEM Servo Booster: 47210-23U11
Nissan OEM Front GTR Brake Disc (upgrade for GTST with proper bracket): 40206-12U01 x2
Nissan OEM Front GTR Brake Pads (needed for upgrade): 41060-12U87
Nissan OEM Front Left Fender Cover Front + Rear Piece: 63845-15U10 + 63843-15U00
Nissan OEM Front Right Fender Cover Front + Rear Piece: 63844-15U00 + 63842-15U00
Nissan OEM Front Fender Cover Clip: 01553-091 x???
Nissan OEM Licence Plate Lamp Assy: 26510-15U00
Nissan OEM Trunk Lamp: 26470-60U00
Nissan OEM Oil Filter: AY100-NS007
Nissan OEM Fuel Pressure Regulator: 22670-74T00
Nissan OEM Fuel Damper: 22675-21U00
Nissan OEM Accelerator Cable: 18201-75T00
Nissan OEM Injector Drop Resistor: 22698-21U00
Nissan OEM Fuel Pump Control Module: 17001-21U15
Nissan OEM Visco: 21082-75T02
Nissan OEM Visco Fan: 21060-75T01
Nissan OEM S1 MAF: 22680-02U00
Nissan OEM Radiator Fan: 92120-15U10
Nissan OEM A/C Compressor: 92600-15U01
Nissan OEM A/C Condenser: 92110-15U00
Nissan OEM A/C Dryer: 92131-17U00
Nissan OEM A/C Evaporator: 27280-15U00
Nissan OEM A/C Pressure Switch: 92137-17U00
Nissan OEM Heater Motor: 27220-2J003
Nissan OEM Heater Matrix: 27140-0E000
Nissan OEM Oil Pressure Switch: 25070-30P00
Nissan OEM Starter: 23300-08U00
Nissan OEM Alternator: 23100-70T16
Nissan OEM Alternator Voltage Regulator: 23215-86L11
Nissan OEM Side Rubber Hood Bumper: 65158-15U00 x2
Nissan OEM Front + Rear Windscreen Washer Pump: 28920-71L00 + 28920-71L10
Nissan OEM Front + Rear Windscreen Washer Nozzle: 28930-15U00 x2 + 28970-15U00
Nissan OEM Front + Rear Wiper Arm Nut Cover: 28882-50J00 x2 + 28782-01U00
Nissan OEM Front Door Left + Right Window Regulator (2dr): 80721-22U00 + 80720-22U00
Nissan OEM Side Indicator Bulb Socket: 26244-30Y00 x2
Nissan OEM Headlight Bulb Harness Assy: 26038-15U00 x2
Nissan OEM Fog Lamp Bulb Harness: 26157-15U00 x2
Nissan OEM Front Wheel Bearing: 40210-33P07 x2
Nissan OEM Rear Wheel Bearing: 43210-AA100 x2
Nissan OEM Rear Hub: 43202-85F00 x2
Nissan OEM Front Hub: 40202-20U10
Nissan OEM Front Hub Bolt: 43222-70T00 x10
Nissan OEM Fuel Rail Spacer (plastic): 17522-10V00 x5
Nissan OEM Fuel Rail O-Ring For Fuel Pressure Regulator: 16618-10V10
Nissan OEM Fuel Rail Seal For Injectors: 16636-72P00 x6
Nissan OEM Injector Bottom O-Ring: 16618-53J00 x6
Nissan OEM Injector Middle O-Ring: 16618-10V05 x6
Nissan OEM Injector Upper Pad/Insulator: 16635-53J00 x6
Nissan OEM Hydraulic Lifter : 13231-79S00 x24
Nissan OEM Thermostat: 21200-42L05
Nissan OEM Boost Control Solenoid: 14956-21U01
Nissan OEM CAS Washer: 13524-D0113 x3
Nissan OEM CAS Bolt: 13505-D0101
Nissan OEM Crank Pulley: 12303-75T00
Nissan OEM Timing Belt Back Cover: 13570-75T00
Nissan OEM Timing Belt Lower Cover: 13560-58S00
Nissan OEM Timing Belt Upper Cover: 13501-75T01
Nissan OEM IAC Valve: 23781-17U00
Nissan OEM IAC Air Regulator: 22660-08U00
Nissan OEM Turbo Oil Outlet 3 Way Connector: 15191-59S00
Nissan OEM Turbo Oil Outlet Pipe: 15197-20P00
Nissan OEM Turbo Oil Outlet Gasket: 15196-73L00
Nissan OEM Turbo Inlet Oil Pipe: 15192-04U00
Nissan OEM Turbo Inlet Water Pipe: 14499-73L00
Nissan OEM Turbo Outlet Water Pipe: 14498-21U00
Nissan OEM Turbo Outlet Elbow Gasket (triangle): 14465-OP610
Nissan OEM Turbo Elbow Bolt: 14434-V0301 x4
Nissan OEM Turbo Elbow Nut: 14432-P7600 x2
Nissan OEM Turbo Elbow Heat Shield: 14441-21U00
Nissan OEM Turbo Inlet Plate Washer/Lock: 14495-V5300 x2
Nissan OEM Turbo Inlet Nut: 14417-P7600 x4
Nissan OEM Turbo Inlet Stud: 14416-V5300 x4
Nissan OEM Exhaust Manifold Stud (93-97): 01151-00471 x12
Nissan OEM Exhaust Manifold Gasket: 14035-75T01
Nissan OEM Exhaust Manifold Heat Shield: 16590-21U00
Nissan OEM Spark Plugs: 22401-1P175 x6 (aftermarket: PFR5G-11)
Nissan OEM Oil Filter Bracket Gasket: 15239-71L00
Nissan OEM Intake Manifold Middle Gasket: 14032-75T05
Nissan OEM Antenna: 28200-22U06
Nissan OEM EGT Sensor: 22740-75T00
Nissan OEM Valve Cover Half-Moon Seal: 11051-58S00 x2
Nissan OEM Fuel Pump Holding Clamp/Nut: 17343-79900
Nissan OEM Fuel Pump Holding Clamp/Nut Rubber Seal: 17342-79900
Nissan OEM Fuel Pump: 17042-21U05
Nissan OEM Fuel Pump Check Valve: 17370-79903
Nissan OEM Fuel Tank Holding Brace Left + Right: 17407-70T00 + 17406-70T00
Nissan OEM Fuel Filler Cap: 17251-79910
Nissan OEM Fuel Filler Grommet: 17240-70T00
Nissan OEM Fuel Filler Tube: 17221-70T00
Nissan OEM Engine Oil Dipstick: 11140-21U00
Nissan OEM Heater Feed Y-Pipe: 14053-21U00
Nissan OEM Rear Muffler Hanger: 20650-60U00 x3
Nissan OEM Front Right Power Window Switch: 25401-22U00
Nissan OEM Windscreen Wiper Motor: 28810-26U00
Nissan OEM Rear Wiper Motor: 28710-15U10
Nissan OEM Oil Cooler Rubber Seal: 21304-17F20
Nissan OEM Steering Column Upper Shaft: 48820-15U00
Nissan OEM Brake Light Switch: 25320-75A00
Nissan OEM Side Mirrors Switch: 25570-71L05
Nissan OEM Washer Reservoir Cap: 28913-71L00
Nissan OEM Left + Right Wiper Link Ball Retainers (if you have "flappy" wipers): 28828-65F00 + 28828-65F01 x2
Nissan OEM Left + Right Indicator Stalk: 25260-0E002 + 25540-15U62
Nissan OEM Rear Spoiler Stop Lamp: 26590-22U00
Nissan OEM Left + Right Headlight Parking Light Bulb Socket: 26240-50C00 + 26240-70Y00
Nissan OEM Stock Downpipe + Stock Backbox Gasket: 20691-0P600 x2
Nissan OEM Catalytic Converter Gaskets: 20692-65J00 x2
Nissan OEM Turbo Oil Return Gasket: 15196-75T00
Nissan OEM Turbo Oil Return Pipe: 15197-75T00
Nissan OEM Turbo Oil Return Pipe Connector (goes into the block): 15191-75T00
Nissan OEM Oil Strainer O-Ring: 15059-V5001
Nissan OEM Rear Driveshaft Outer + Inner CV Joint: 39211-73L00 x2 + 39711-73L02
Nissan OEM R33 Front Caliper Pad Retaining Pins: 41217-30P00
Nissan OEM R33 Rear Caliper Pad Retaining Pins: 41217-43P00
Nissan Drivers Side Wiper Arm: 28881-15U00
Nissan Drivers Side Wiper Arm Bolt Cover: 28882-50J00
So far, I have these part numbers:
R33 GTST OEM Front Brake Discs: 40206-21U00 x2
R33 GTST OEM Oxygen Sensor: 22690-83T10
R33 GTST OEM Knock Sensor: 22060-56S10 x2
R33 GTST OEM Propshaft Front Seal: 38189-N3111
R33 GTST OEM Propshaft Rear Seal: 38189-Y0810
R33 GTST OEM Valve Cover Gasket Set: 13270-58S01 + 13270-58S11
R33 GTST OEM Turbo Inlet Gasket: 14415-4P200
R33 GTST OEM Piston Rings STD (86mm): 12033-21U10
R33 GTST OEM Center Exhaust Hanger (Square): 20610-52F00
R33 GTST OEM Front Caliper Rebuild Set: 41120-30P25
R33 GTST OEM Rear Inner CV Boot: 39741-03P28
As for the fuel filter... I personally use Mann WK613 - it's from an Alfa 164, and I can confirm, after doing extensive search, I could not find a stock fuel filter with 8mm inlet/outlet, that would flow more. Audi S2's filter (Mann WK725) has even more flow, but it uses banjo's for inlet/outlet...
Good man. Thanks for the numbers. Will add them to original post.
As for the fuel filter, finally found a Nissan OEM one with straight pipes either side. The gtr version has a 90 bend on one side. Still technically fit. However the 300zx fuel filter, which is considered an upgrade, fits the r33 GTST and is straight. Allows for more fuel.
Debating to get that one or just normal one for mine
Sent from my SM-G920F using Tapatalk
While browsing my R33 project pics, I found some more part numbers:
I took my time, while browsing for parts for my R33 (clutch + brake overhaul soon) and found a few more part numbers, which I feel are serviceable (mostly) items on our GTST's:
A few more...
A few more and we will have all the part numbers, for all the parts, that I feel are serviceable parts on 20+ year old cars. At least those are the type of items I sell to customers at work. I want this list to be as helpful as possible. And of course, so we won't have to start up that old pc, for finding parts :)
Discussion Starter · #14 ·
For anyone needing any of the above parts let me know as I can do most OEM parts a fair bit cheaper than Nissan prices.
One example...... RB25DET engine rebuild gasket kit - Nissan UK £248.50, I currently have them at £159 plus delivery.
Good man Wayne :notworthy
It isn't an OEM part number, but I would still like it in the list. I had to order a washer pump for my P205, and it turns out it's exactly the same as on our R33's - perhaps even on an R32/R34. It even fits my Forester SF5. If I recall, OEM Nissan washer pump is ~70€, P205 ~8€:
Aftermarket R33 Washer Pump (single outlet): 722447 (Topran)
'talla
Discussion Starter · #18 · (Edited)
updated to include
15/06/2017 - part numbers updated
1 - 20 of 22 Posts
