I've found some tempting wheels for my GTS just to get rid of thos standard ones for now
They're 17's with a 7j and a 35 offset.
I've used the wheel calculator but a little worried about how much they'll pertrude out.
The car is at standard height at the mo but I'll be lowering it at some point 32mm front 30mm rear.
I'm just after some reassurance that they will fit before and after decking with no arch rolling.
Ta vey mooch
I wouldn't worry to much about being to close to the guard because there going to be way off, with that offset you should be looking at whether they clear the struts and brakes
ok. I was under the impression that the lower the offset the further out the wheels will sit? According to the wheel calculator there will be another 1mm inside clearance.
so in that case would they sit ok?
