1 - 14 of 14 Posts
Well I woke up today and decided it was time to make a start on my engine re-build. The engine is now fully stripped and the block is now ready to goto the machine shop and the head is ready for a little tinkering !!! :D
Here are a few pics, I will post more once I have sorted through them !!
From this
to this !!!
:eek: :(
Nice turbos Richard
What make are they ?
Happy New Year, dont get those little bags muddled up
Tim (my first post, couldnt think of anything original sorry)
Should keep you busy for a couple of days:) What you going to do to the block, just a re-bore?
its
Horrifying when they are apart init, so many bits...,
Hello Timothy, youve made it then:D
The turbines are those Greddy 125797846 thingies arent they?
If your heading for lots of power, you could get the block 'Cryogenic treated'. It's a method of freezing the block with liquid nitrogen for a period of time, then heated to about 300 degrees, the process is repeated several times and has the effect of tempering the cast making it very strong. I'd also look at Extrude honing of the water jackets, helps eliminate hot spots in the cooling galleries.
2.8 HKSステップ3 、
engine
Oh my god, I do so hope you have numbered all that lot... either that or you have a Bob Monkhouse memory...
:D
2.8 HKSステップ3 、
I waited
By the phone for the call to come and help.. but the call never came...:(
so it was your engine on MIGWeb.
I thought it was, but wasn't sure, now this has removed all doubt!
What did you do to it?
Discussion Starter · #12 ·
Paul, theres not alot you could have helped with. I had to be the only one to take it apart as i`m going to be the one putting it back together!!!
The engine suffered a spun bearing on number 6, which may be due to low oil level and cornering a little bit hard causing a oil surge!!! The Crank is dead as are all the bearings etc etc.
richard
2.8 HKSステップ3 、
Help
I could have made the tea and brought the doughnuts...:D
1 - 14 of 14 Posts
