oil and water fittings banjo bolts and drain pipe needed for rb25det gt3071 turbo install
just thought i would mention, have you thought if you need a oil restrictor?, i just saw you mentioned you wanted banjo bolts and normally the restrictor is a male to male thread on these for the feed.oil and water fittings banjo bolts and drain pipe needed for rb25det gt3071 turbo install
