1 - 17 of 17 Posts
Hi folks this is how my oil catch can is rigged up been like this since I got car is it correct? If not what's needed doing
126311
Really good info there about catch tanks etc
Yes it is very helpful however is mine plumbed the way it states or is mine wrong, I read somewhere about a s pipe cheers
It seems fine to me. Your Line:IN is taking it from the cover and your LINE:OUT is taking it away with hopefully less vapour etc if the catch can is baffled.
The only amendment I would make is to change your cover fitting to get rid of that hoop over the top and route more direct to the catch can.
The 2 way port where your catch can hose currently connects. I thought you could get like a 90degree angle one but I cant seem to find any, never mind..
Discussion Starter #13
Sparkso thank you mate I'll block them off tonight, I'll cut pipe and bolt it up, will it make much difference once done?
Discussion Starter #15
That's done I got a nice snug fitting bolt screwed it in do I need to jubilee clip or cable tie over the bolt or should it be ok
1 - 17 of 17 Posts
