Weird User
HAPPY NEW YEAR EVERY1
On the engine block there is the oil filter location.. (a small hole in the middle, and outer area)
does the oil pump out of the small hole?
the oil cooler & Relocation of oil filter kit I got,
I attached a pic.. please confirm my lines are correct or use the numbers as a guide for me..
thanks fellas!
Shaun
edit
P.S. When I recieved the 2nd hand kit the orings had gasket maker all over them, but I cleaned it all off a got brand new o-rings...
should I also apply gasket maker or without that crap!
Weird User
thanks for your reply mate.. Happy NY
I looked closely at an oil filter and noticed that the centre part is output.. so
I'd wanna reverse the idea of having dirty oil pass the cooler!!??!!??
so based on numbers
start at
2 -> 4
3 -> 6
5 -> 1
would that be correct?
R33 GTS25-T
so based on numbers
start at
2 -> 4
3 -> 6
5 -> 1
Yeah, 2-4, 3-6, 5-1. That's having the clean oil through the cooler. :iagree:
