1 - 8 of 8 Posts
19 row or 34 row... ????
Which would be best for 450/500bhp ...
hi shane im using a 13 row mocal now, my oil temps at nurburg went to 125+ and the air temp was 35 degrees (bloody hot), at knockhill the air temp was 14 im guessing, and the oil temp went to 110 which is ok, but im fitting a new 21 row cooler tomorrow so ill let you know which is the best way to go mate, a 34 row is too big imo, the oil needs a certain temp to be efficient. on average my oil temps vary from 75 to 85 weather depending and at normal driving, not track driving, so once this one is fitted ill know how much cooler it will be mate....ill post up tomorrow and let you know mate....:naughty: bear one thing in mind when i run 400bhp the temp was 10 degrees lower than now at 650bhp, the more power the higher temps...;)
No probs Keith, Thanks .... I await your post....:ylsuper:
:notworthy
Im sure my power fc reads 82/85 on norm driving and erm... fast :D
On general driving it should be 84 degrees, hard drivning 90-100 degrees and out on track 115 to a max of 125 degrees.
1 - 8 of 8 Posts
