don't get what your meaning
do you want to know how to install it?
where to mount it?
where to mount it?
Thats what i was trying to get at. Where did you get the T piece from, also the size. Did you need to drain any oil when taking out the original one and replacing it with the T piece. Could i just unscrew the Nissan sender and replace it with the one i got with the gauge :bigthumb:I bought a t piece adapter and screwed the adapter into where the std sender is located then ran the 2 senders from that
Cant remember the thread size im afraid, i got it from motorscope in northallerton, but i would imagine demon tweeks or similar would stock something like that too. No need to drain oil, however you will get a slight dribble when you remove the std sender.Thats what i was trying to get at. Where did you get the T piece from, also the size. Did you need to drain any oil when taking out the original one and replacing it with the T piece. Could i just unscrew the Nissan sender and replace it with the one i got with the gauge :bigthumb:
