1 - 11 of 11 Posts
Irish Drifter :D
2nite while spinnin around i noticed that whenever i stop the car the oil pressure guage needle drops down to 0 for a second and then just goes back up to normal. only happens whenever the car stops and goes straight back up again, doesn happen while im drivin at all.
checked the car for oil and everything seems fine. any1 heard about this happenin in a 32 gtst? cud it just be a dodgy oil pressure sensor or switch? the oil light doesn come on at all, only when i turn on the ignition to start the car as its supposed to. there is no knockin from the engine and everything sounds as it should.
its the standard guage in the dash btw...any help appreciated
the standard gauges are known to be as reliable as general banter is being sensible :rofl:
get an aftermaket one on there buddy if your unsure :)
nice one lads :D hearin from a good few ppl about havin problems too
actually mate my standard one is working perfect with no problems :rofl: but then my speedo head has been modded properly no little box in mine :rofl:
Irish Drifter :D
didnt say everyone was havin problems, just said i heard a good few were
Nissan Skyline r33 gts-t
mines doing this also r33 gts-t
were is the oil pressure gauge sender unit?
so when i do an oil change i can clean it out?
1 - 11 of 11 Posts
