Hi guys!
Does anyone know if this o'ring has to be placed between the pickup pipe and the gasket? Because when I am tightening up the bolts of the pickup pipe, the o'ring strangely squeezes too much that it doesn't stay in place. Do I need to fit it...is it a must?
I am sending a diagram to show which o'ring I am referring to.
Terry
The diagram clearly shows it between pickup pipe and gasket and I would say yes it’s a must have you don’t want to have an issue in this area as consequences could be disastrous IMO
Are you sure you have the right O ring
The o'ring came in the package as a set. There weren't any other o'rings in the package.
Terry
So having a look around most of the Nissan engines seem to show that I ring as being where you diagram shows but I have just seen a diagram of a gtr that doesn’t show that I ring at all so confused me a little
Maybe you just use some sealant instead of the o ring, I don’t know mate
I am not a mechanic there are others here who would know if they log in?
