i am thinking of fitting a oil temp gauge in the car do i have to use a plate between the oil filter or can i use the standard oil temp sensor on the engine?
i dont think the engine has one as standard, either use a sandwich plate or put a sender in the sump as its more accurate
Track addict
No it does not have one as std, and yes the sump is the best place to fit an oil temp sensor
woo hoo i was right then :D
