1 - 12 of 12 Posts
Registered Chump
id be checking under the car for spots and in the cooling sytem for cream, boost hoses etc.
rocker cover gaskets quite common so im told for a leak.
i did my oil change 4000 miles ago still the same amount in there.
Mine never burnt a drop of oil or lost any and no engine bar a ****el should use oil
Old Git Having Fun....
Same here... 146000 km and uses no oil, no leaks either. Oil stays clear for ages too.... I think you need to investigate - get someone to follow you looking for smoke maybe?
Take the standard oil pressure gauge and chuck it away as there famous for not reading correctly
agree std pressure gauges lie like a cheap chinese watch! check for smoke on startup (valve stem seals) leaks on the turbo, leaks on the sump gasket etc as any healthy Skyline engine should never use a drop tbh!
RSP Tuned 515.7 BHP
what oil you putting in it mate?
1 - 12 of 12 Posts
