Guys - I've got a 94 33 GTS-T . .
I stripped down the drivers side door because the electric window has decided to stop working. :disappointed:. We did a continuity check with a multi meter on the switch itself, and that itslef, was working fine. I need to however check the relay(This may indeed be the problem because there is a burning smell at the points), the black box bolted on beneath the door handle and the motor. .
2 questions at this point . .
(1) Obvious thing is relay burnt out. But to double check do i have to open the relay somehow ? Id so, How ?
(2) how on earth do I get the motor out from behind the door skin ?
Any tips on this matter wil be much appreciated chaps. The window is slightly open at the moment, and I've got it taped up with plasric bin bag !!!
