Track addict
Thought it might come in handy, i know i have one or two nissan part numbers kicking about oil filters, belts etc.
I have seen it on other forums and it seems to work ok.
Just a thought any way chaps
good idea
I like this :)
Would need a lot of combined help from member to set it up though.
crack on then gb. you could start a thread asking for details and give it a few weeks then take all the info off it and put it into a locked thread that only you can alter. put in the thread also that if anyone has new numbers to pm them to you so you can add them to the list :)
I am liking the idea
to begin with i have copied these from another forum - all NISMO parts though
http://forums.gtrcanada.com/showthread.php?t=22628
Just ignore the pricing etc -- and feel free to delete if my post is not appropriate
and i also have Nissan FAST if needs to be cross checked.
1. Engine part
NO. Part name Part number Unit cost P/C Summary
1 VERUSPEED motor oil KL101-RN621 2,940 - 1 liter can Viscosity: For 10W-60 sport driving 100% chemosynthesis oil
2 VERUSPEED Motor Oil KL101-RN624 10,290 - 4 liter can
3 VERUSPEED Motor Oil Filter NS5 15208-RN020 1,890 - RB26DETT
4 レーシングラジエターキャップ 21430-RS012 3,360 1 Injection-valve open pressure =0.13MPa (≒ 1.3Kg/c‡u) all car which excludes the cold area specification car
5 Oil Filler Cap 15255-RN012 8,610 1 Aluminum make buff finish stainless steel make logographic plate attaching
Screw size =M32×3.5
6 Oil Filler Cap (Ratchet type) 15255-RN013 6,510 1 Aluminum die-cast make silver paint
7 Low Temperature Thermostat 21200-RS580 7,350 1 Opened valve temperature approximately 62 ℃ (genuine = 76.5 ℃)
8 Sport Air Filter 16546-RN075 8,925 1 Genuine exchange type
9 Verudi eggplant Potts catalyser 20800-RS596-R2 84,000 1 It is low anti- pressure metal catalyst flange diameter φ 80
10 Repair gasket kit 1010A-RR580 52,290 1 Metal gasketfor competition (T = 1.2) + ENG overhaul gasket kit
11 Head gasket 11044-RRR45 33,600 1 Metal makeT=0.9mm silicon coating application for competition
12 Head gasket 11044-RRR46 35,700 1 Metal makeT=1.2mm silicon coating application for competition
13 Intake Manifold 14110-RSR45 162,750 1 The intake collector single unit, vacuum piping for brake/clutch master, the vacuum hose for clutch master, re-setting of gasket attachment & ECM which are necessary for the bracket and installation is needed
14 Intercooler 14461-RS580 189,000 1 Aluminum make and core size H270×W600×D100 (mm)
15 Air flow meter 22680-RR580 36,750 2 Measurableair quantitative twin 2400kg/h single 1200kg/h ECU main point adjustment for competition
16 Exhaust manifold gasket 14036-RSR45 15,750 1 Metal 3 structure t = 1.3mm
17 Turbocharger 14411-RR581 197,400 2 ECU main pointadjustment for R32 GT ・ ルマン of competition
18 Turbocharger 1441A-RSR45 330,750 1 R1 turbokit installing kit attaching ECU main point adjustment for competition
19 Exhaust outlet set 1444A-RSR46 102,900 1 At the time of R1 turbo kit installing Inside stainless steel thin forging exhaust interference decreasing divider attaching FR pipe adapter unit diameter φ 60
* Only ヴェルディナ NE1 series equipped car
20 Heat sealed tape 14450-RN050 3,255 1 Width 50× length 3000 (mm) When the exhaust outlet is installed, combined use recommendation
21 Heat sealed tape 14450-RN100 5,145 1 Width 100× length 3000 (mm)
22 Heat sealed tape 14450-RN200 9,660 1 Width 200× length 3000 (mm)
23 Injector 16600-RR420 13,650 6 Emission quantity 555cc/min for competition
24 Injector 16600-RRR60 14,175 6 Emission quantity 600cc/min for competition
25 Fuel pump 17042-RR581 42,000 1 Emission quantity4.6L/min for competition (a t p = 3.0kgf/ c ‡u) harness, connector and strainer attaching
26 Pressure regulator 22670-RR580 12,600 1 Adjustable fuel pressure. 196-588 kPa(Flow :40l/h, 2-6kgf/cm2)
27 Oil pump 15010-RR580 100,800 1 Gear section hardness for competition: HRC50 - As for 51 emission quantity equality to genuine products
28 Oil pan baffle plate 11113-RS580 44,100 1 Hydraulic decrease measure at the time of side G
29 Air-cooled engine oil cooler kit 21300-RS583 204,750 1 Core size (mm) 155x300x50 11 step
30 Oil separator 11830-RSR25 47,250 1 Φ 50 cylinders
31 Strengthening timing belt 13028-RSR45 15,750 1 Tensile strength 1.2 time heat-resistant 1.8 time cutting strength 3 time resistance tooth being lacking worn 9 time
32 Sparkplug 22401-RS238-7 2,940 6 Hard tuning,
For circuit travelling Racing plug heat range # 7 1 these packs
33 Sparkplug 22401-RS238-8 2,940 6 Racing plug heat range # 8 1 these packs
34 Sparkplug 22401-RS238-9 2,940 6 Racing plug heat range # 9 1 these packs
35 Sparkplug 22401-RN010-6 3,990 3 For street Iridium plug heat range # 6 2 these packs
36 Sparkplug 22401-RN010-7 3,990 3 Iridium plug heat range # 7 2 these packs
37 Sparkplug 22401-RN010-8 3,990 3 Iridium plug heat range # 8 2 these packs
38 Engine mount 11200-RS580 16,800 1 1 unit of front rear kit
39 Engine mount 11220-RS580 4,200 2 Front single item Mount bushing assembly
40 Engine mount 11320-RS580 8,400 1 Rear (mission)
41 Intercooler piping set 1446A-RS580 71,400 1 Aluminum casting buff finish
42 スポーツラジエター 21410-RS580 136,500 1 Aluminum make core size: 658×374×36mm
XX Intake Camshaft for Solid Lifter Working Angle: 64° ,66°or 68°with Valve Lift:9.25mm & Center Angle 113° PART NO?
72,900
XX Exhaust Camshaft for Solid Lifter Working Angle: 62°,64° ,66°or 68°with Valve Lift:9.25 PART NO?
72,900
2. Power transmission type part
NO. Part name Part number Unit cost QTY Summary
1 Sport clutch kit contents: Disk & cover lightweight flywheel release bearing 3000S-RSR25-E 90,300 1 - '93/2 Kappa mix
2 Sport clutch Kit contents: Disk & cover lightweight flywheel release bearing 3000S-RSR25-N 84,000 1 For ノンアスキット and refreshment
3 Sport clutch kit contents: Disk & cover lightweight flywheel release bearing 3000S-RSR35-E 100,800 1 '93/2 - Kappa mix
4 Sport clutch kit contents: Disk & cover lightweight flywheel release bearing 3000S-RSR35-N 94,500 1 For ノンアスキット and refreshment
5 Super kappa mix 3000S-RSR25-H1 115,500 1 - '93/2 clutch system 420PS corresponding contents: Set of aluminum make cover, kappa mixed disk and lightweight flywheel
6 Super kappa mixed twin 3002A-RS594 180,600 1 - '93/2 PushType Twin plate clutch system 670PS corresponding high power specifications contents: Aluminum make cover (1000kgf), set of kappa mixed disk, lightweight flywheel and release bearing
7 Super kappa mixed twin 3002B-RS599 182,700 1 '93/2 - PullType Twin plate clutch system 640PS corresponding high power specifications contents: Aluminum make cover (950kgf), set of kappa mixed disk, lightweight flywheel and release bearing
8 Super kappa mixed twin COMPETITION model 3002A-RR593-C 182,700 1 - '93/2 PushType Twin plateclutch system 740PS corresponding high power specifications contents for competition: Aluminum make cover (1100kgf), set of kappa mixed disk, lightweight flywheel and release bearing
9 Super kappa mixed twin COMPETITION model 3002B-RR598-C 184,800 1 '93/2 - PullType Twin plateclutch system 780PS corresponding high power specifications contents for competition: Aluminum make cover (1150kgf), set of kappa mixed disk, lightweight flywheel and release bearing
10 Release pivot 30537-RS581 2,940 1 - Prevention of breaking at time of '93/2 chrome molybdenum steel strengthening clutch installing
11 Clutch hose 46211-RS580 6,825 1 - '93/2 Stainless steel mesh
U-tube abolition adapter attachment
12 46211-RS581 6,825 1 '93/2 -
13 Clutch pedal bracket 46550-RS585 7,875 1 Guaranteeing the rigidity of approximately 1.75 times
14 Lightweight flywheel 12310-RSR21 44,100 1 Single unit weight = 6.88 (STD = 9.65) for NISMO make single plate clutch
15 Clutch disk (kappa mix) 30100-RS240 31,500 1 - '93/2 You use with cover bonding power 920kgf set
16 Clutch cover 30210-RS245 33,600 1
17 Clutch disk (kappa mix) 30100-RS252 32,550 1 '93/2 - You use with cover bonding power 1050kgf set
18 Clutch cover 30210-RS255 35,700 1
19 T/M baffle plate 32150-RS590 5,775 1 Transmission baffle plate steel make for N1 race/lace
20 Solid shift 32839-RN595 16,800 1 10% short stroke conversion
21 Quick shift 34110-RN595 35,700 1 Lever ratio modification 25% short stroke conversion joint rubber hardness rise
22 GT L.S.D. Pro 38420-RSS20-E 115,500 1 2WAY Initial torque 3 stages (5-8-12kg m) as for modification possible installing kit equipped active LSD car installation failure
23 38420-RSS15-E 115,500 1 1.5WAY
24 GT L.S.D. Pro TT model 38420-RSS22-E 115,500 1 2WAY As for installing kit attaching active LSD car installation failure
25 38420-RSS17-E 115,500 1 1.5WAY
26 GT L.S.D. 38420-RS020-A 96,600 1 2WAY Mechanical cable type 4 pinion for installing kit attaching rear diff.
27 38420-RS015-A 96,600 1 1.5WAY
28 Front L.S.D. Kit 38420-RSF16-A 113,400 1 Kit for installing (oil seal and O ring, bearing 2) attachment
29 VERUSPEED L.S.D. Oil KLD80-RN911 2,888 - 1 L can 80 W -90 for 100% chemosynthesis oil rear diff.
3. Brake part
1 Brake hose set 46200-RSR25 20,790 1 Superfine knitting stainless steel mesh durability UP
For competitionGT-R (the genuine ブレンボキャリパー equipped car is excluded) Rotor proper temperature: 200 ℃ - 800 ℃
Coefficient of friction: 0.3 Or more 摩 material: High carbon metal
2 R-tune brake pad (front) 41060-RRR40 25,200 1
3 R-tune brake pad (rear) 44060-RRR40 23,100 1
4 R-tune brake pad (front) 41060-RRR45 27,300 1 Genuine ブレンボキャリパーequipped car for competition Rotor proper temperature: 200 ℃ - 800 ℃
5 R-tune brake pad (rear) 44060-RRR45 25,200 1
6 S-tune brake pad (front) 41060-RN25P 18,900 1 For GT-R (the genuine ブレンボキャリパー equipped car is excluded) Rotor proper temperature: Usual limits - 500 ℃
Coefficient of friction: 0.3 - 0.5 μ 摩 materials: Non ground
7 S-tune brake pad (rear) 44060-RN11P 16,800 1
8 S-tune brake pad (front) 41060-RN27P 23,100 1 Genuine ブレンボキャリパー equipped car Rotor proper temperature: Usual limits - 500 ℃
9 S-tune brake pad (rear) 44060-RN13P 21,000 1
10 The sport brake rotor right 40206-RSR45 30,450 1 Genuine ブレンボ make caliper - equipped car front private street and plainness type for sport travelling
11 The sport brake rotor left 40207-RSR45 30,450 1
12 High performance brake kit 40000-RRR35 472,500 1 Genuine ブレンボキャリパー equipped car φ 355 disk rotors, Brembo make large-sized caliper - R-tune pad (front and back), set of fitting kit
13 VERUSPEED brake fluid ESP01-RN111 4,725 - BF-5 standard product glycol 1L can entering
14 Brake cooling air guide set 41180-RSR45 20,790 1 Installing (the accessory to attach into the tension rod), the ABS resin make 16 inch wheel equipped car is excluded
4. Suspension chassis part
1 For long hub bolt front 40222-RS035 6,825 1 50mm Serration diameter 14.3mm type 10 set selection use & standard item length =42mm
2 For long hub bolt front 40222-RS045 7,035 1 60mm
3 For long hub bolt rear 40222-RS015 6,825 1 50mm Serration diameter 13.0mm type 10 set selection use & standard item length =41.5mm
4 For long hub bolt rear40222-RS025 7,035 1 60mm
5 Aluminum load wheel LM GT4
* As for -WH white, as for -BR bronze, As for -SL silver 40300-RN924- * 70,350 4 Aluminum alloy make full forging 1 piece 5 spoke type 17×9.0J OFF 22 reference tire size: 245/45-17
6 40300-RN933- * 76,650 4 Aluminum alloy make full forging 1 piece 5 spoke type 18×9.0J OFF 22 reference tire size: 235/40-18
* Because of the 4WD car, also the front and the rear the tire and the wheel of identical size use. The aluminum wheel is all incoming order productions
7 G-ATTACK S-tune
Suspension kit 5300S-RS580 173,250 1 Attenuation power 5 step adjustment system (Fr 、 Rr) height change fare: Fr-20mm Rr-15mm
Spring rate: Fr54.0 (5.5) Rr44.1 (4.5) N/mm (kgf/mm)
8 S-tune suspension system 5000S-RS580 231,000 1 S-tune suspension kit and stabilizer kit (front and back)
9 G-ATTACK S-tune HA
Suspension kit 5300S-RSR25 241,500 1 Height adjustment type attenuation power 5 step adjustment system (Fr and Rr) attenuation power (3rd step) N (kgf) at the time of 、 0.3m/s 、 Noboru/pressure Fr1912/1079 (195/110) Rr1373/686 (140/70) Spring rate N/mm (kgf/mm) Fr53.9 (5.5) Rr44.0 (4.5) Height change fare mm Fr approximately -5 - -35 Rr approximately 0 - -30
10 G-ATTACK R-tune Suspension kit 5300R-RS580 399,000 1 Height adjustment type Noboru pressure simultaneous 20× pressure side independence 18 step 2way attenuation power adjustment
Reservoir tank attaching height change generation (mm) Fr approximately 0 - -60 Rr approximately 10 - -50 reference recommendation height (mm) Fr approximately -30 Rr approximately -20 spring rate: Fr 88.3 (9.0)
Rr 78.4 (8.0) N/mm (kgf/mm)
11 Front stabilizer 54610-RSR25 39,900 1 Major diameter: φ 22.6mm (air), spring constant: 18.1 (1. N/mm (kgf/mm)
12 リアスタビライザー 56220-RSR25 36,750 1 Major diameter: φ 27.2mm (air), spring constant: 113.9 (11.6) N/mm (kgf/mm)
13 Stabilizer kit 54600-RSR25 63,000 1 Approximately kit and private strengthening bush (body side) attaching
14 Front strut tower bar 54420-RNR25 31,500 1 Aluminum alloy make elliptic pipe (bar section) M.C.S attaching
15 Rear tower bar 55420-RNR20 28,350 1 Installation inside trunk
* Main point trunk trim processed aluminum alloy make circular pipe (bar section)
16 Circuit link 54501-RS585-R 34,650 1 Right side set Contents: The upper link bracket, you use with trance berth link and tension rod strengthening bush pressing in end set
17 54502-RS585-R 34,650 1 The left side set
18 Tension rod set 54460-RS580 24,150 1 Left and right 1 set bush pressing in end
Silver paint (in case of circuit link installing it is unnecessary)
19 Front upper link set 54556-RS580 42,000 1 Left and right 1 set strengthening bush pressing in end silver paint
20 Rear upper link (anterior) set 55125-RS580 11,550 1
21 Rear upper link (back) set 55135-RS580 14,490 1
22 Rear A arm set 55550-RS580 28,350 1
23 Rear axle bush upper side 55157-RS580 1,470 4 Rubber hardness rise main point pressing in job
24 Rear suspension mount bush 55442-RS580 5,250 4
25 Rear shock absorber - bush 56219-RS580 4,935 2
26 Diff. mount bush kit 55401-RS590 24,150 1 1 unit set rubber hardness rise main point pressing in job
27 Upper mount bush upper 56217-RS580 630 4 Front & rear common rubber hardness rise
28 Upper mount bush lower 56218-RS580 630 4
29 リアスタビライザーブッシƒ… 54613-RS580 630 2 For φ 25.4 genuine stabilizers
30 Steering gear mount bush 54440-RS580 5,250 1 1 unit kit Rubber hardness rise
31 Under floor reinforcement bar (front) 54422-RSR25 42,000 1 STKM (carbon metal tubing)
32 Under floor reinforcement bar (trunk) 79175-RSR25 36,750 1 Duralmin
5. Interior exterior part
1 Floor mat 74902-RNR25 20,790 1 5 mat specification over lock finished black
2 Steering wheel boss 48416-RN630 9,450 1 '91/1 - air back non car
3 Horn button 48417-RN001 2,100 1 NISMO logograph & horn mark entering major diameter φ 60
4 Shift knob (for M/T) 32865-RN011 5,460 1 GT shift knob special software urethane make NISMO hallmark entering
5 Shift knob (for M/T) 32865-RN003 4,200 1 Adapter unit screw size 10mm This leather make NISMO logographic batch attaching
6 Shift knob (for M/T) 32865-RN004 7,140 1 Aluminum make chrome plating finish
NISMO logographic hallmark entering
7 Shift knob (for M/T) 32865-RN005 7,140 1 Aluminum make black alumite finish
8 Shift knob (for M/T) 32865-RN009 7,980 1 Aluminum make Carbon & aluminum twilight plating finish
9 Shift knob (for M/T) 32865-RN006 4,200 1 Adapter unit screw size 10mm & 12mm ジƒ…ラコン make white "brim" attaching
NISMO logographic paint entering
10 Shift knob (for M/T) 32865-RN007 4,200 1 ジƒ…ラコン make black "brim" attaching NISMO logographic paint entering
11 Shift knob (for M/T) 32865-RN008 16,800 1 Titanium make titanium it starts shaving, the item NISMO logographic hallmark entering
12 White meter set 24810-RN584 81,900 1 - ' For 91/8 Speed: 320 Km/h indication
Tachometer: 11000rpm indication
13 24810-RN580 81,900 1 '91/9 - business Speed: 320 Km/h indication
14 Speedometer 24820-RN582 38,850 1 - For '91/8 NISMO logographic entering speed: 320 Km/ h indication
15 24820-RN583 38,850 1 '91/8 - business NISMO logographic entering speed: 320 Km/ h indication
16 Sub meter 24845-RN581 47,250 1 Only three connected white meter set boost meters modification of indication
* The above-mentioned price is consumption including tax straw raincoat itself price
