Hello All
Well looks like my first post is a technical help question. Isn’t that always the way :(
My passenger door won’t unlock. G/f managed to slam the passenger door shut in the locked position and now I can’t unlock it. Tried via key, central locking, switch on drivers console & of course manually. The locking latch moves but the door isn’t opening. The locking motor makes a funny whine now (guess it’s stuck or not happy)
Any help would be greatly appreciated, I’ve only had the car on the road for 8 hours :swear:
DS
hippy
you will have to get the doorcard off with the door closed i think,arkward but not impossible
dont think thats possible the door card has 3 screws underneath it so you can tget to it unless the door is open..only way your going to get to it if you rip the doorcard off then buy another 1
I'm bringing sexy back
you can get the door card off while closed, you just need to take the seat out. this is speaking from experience had a very similar problem to yours.
confused.com
note to self dont let girlfreind near car again! it sounds like something jamed somewhere. i dont supose you unlock it withthe key and someone push from the inside might budge something?
Well finally got this sorted. Thanks for all the help. wire coat hanger and about 15mins job done, door open (mental note - order better alaram system)
Door card off, plastic seal off, CAN of wd40. Lock fixed. Think it was stiff as the car has been standing for a while. Nothing broken but the lock was very stiff before attack of the WD40....
All happy again...
DS
hippy
wd40 will dissipate quite quickly,i would put some spray grease in there
glad you got it sorted though
