1 - 2 of 2 Posts
Hello again all, just looking for an a few answers as ive been searching for 2 days now and failed lol
1. The r34 pcv valve in my car has no gromet, although its a very tight fit does it need 1?
2. Is the pcv hose from manifold to rocker cover the same on the r33 and the r34 as it seems to be impossible to get a r34 one in aus?
Thanks in advance
As long as the fit is airtight it should be fine, as for the hose, you could use any other PCV hose from another turbocharged car as long as it will fit and it has the one way valve the correct way around.
However you could just junk the idle/low throttle side and just stick with the full throttle side/and or fit a catch can to it.
Plenty of info here.
http://www.skylineowners.com/forum/showthread.php?t=159322
1 - 2 of 2 Posts
