I noticed a vibration noise comin from under my timing belt cover (cam cover) as you can hear from the attached sound clip from looking through previous posts on this site I narrowed it down to idle tensioners on timing belt
I brought it to a performance/tuning center that specialise in skylines and they couldnt really tell me a hole lot without bookin it in for a few tests because:
It is burning a bit of oil there is a bit of petrol in oil ( I think there is a bit of petrol in oil cause burst intercooler 3wks ago nd it was overfueling) Timing wasnt set when ever last owner had it so timing is all over the place oil in sump is getting a bit of back pressure
It is booked in for Compression test, cyclinder leak test, Oil pressure test, and Octane Set up
So what do people think is it really serious???? hopeing i wont need rebuild
How Health is my engine????
Any help would be great thanks
Discussion Starter #2
Sound Clip
Sorry couldnt upload sound clip but you will find it in search under
Rattle on Cold Start? ( 1 2 3 )
dazzler22
Its on page 2 thanks sorry
User of V-power
Hiya mate, I still have this rattle on mine but im still not sure that it is the cam belt idler/tensioner or the air con, a mechanic looked at it the otehr day and he thaught it was the air con. other than that i go no troubles, dosent use any oil and none of the other problems you are mentioning,
does yours sound the same as mine? (gonna hit that old thread of mine in a mo) or did u upload a seperate sound clip?
Dazzler
The same
It is 100% match to that of ur the problem was it is a hour drive down to the place and the noise had gone out of it again i went down and when i got home and she cooled down it was as loud as ever but it is booked in for them tests and we will just hav t see what happens
