Hello.
Im new on the forum here, im from sweden so have patience with my sometimes bad spelling in english!
Im going to change pistons and cranks in my car this coming winter, and im going to aim for 600+hp on the wheels. My question is which pistons and cranks would be good for this, i have found these ones, one the swedish Skyline forums people say that they are socalled "good ****", i suppose they mean that its cheap at the samt time good.
http://www.cnc-motorsports.com/product.asp?ProdID=21734&CtgID=21733
Have someone ordered from CNC motorsports? Can i trust them fully?
And is there anything else i should change during the planned high power outtake?
The only things ive heard that would be good to exchange to is the top bolts, they are ARP now. And the thing between the cylinders and the valves&sparks, its an TOmei steel 3mm, for the cooling thereis HKS oilrelocation kit mounted and a HKS Alu water cooler with dual electricity fans, this with N1 oil pump and N1 waterpump. Thereis alot more specs on the eng but theese things should keep the engine in a good temperature while the engine shouldn´t brake down?
The car is a Skyline R33 GT-R which has this summer had a GT35R turbo, with 600cc nismo injectors. The turbo has been running in 1.5bar and when the Tomei 264 cams start att 6500rpm it has been a real kick up to 9000rpms! But a few weeks ago my oil pressure dissapeared so thats why the whole engine will get a tune up with a lot of new parts.
Greetings from Sweden, // Mattias
