G
Guest
·Hi all and sorry for the long post i,m just trying to give as much info as possible.
Only had the R32 GTR a couple of days and i,m going through all its faults etc, This is my first RB26 engined car and i just dont want it to be a lemon!
From the begining:
I got the car knowing it has a misfire problem and hadnt been run for months:
Ive sorted that its just a coil pack (as usual) so i need to get a set
Please note that on the video the cars only running on 5 cylinders!
Other problems, i noticed the coolant expansion bottle was empty and the radiator needed water too (about 3 pints)!
So i was thinking maybe headgasket also it has a cheap after market radiator cap fitted which had some evidence of leakage around it.
So i decided to remove the radiator, flush it through, flush the coolant system refill with coolant/antifreeze also did the oil and filter at the same time.
No oil in the water and no water in the oil, no gunk on the radiator cap or oil filler cap ........ive refitted and so far so good, holds temp etc no problems.
Just to be on the safe side i did a compression test this morning
All spark plugs were good and not wet or oily
I got these results 1-150 2-148 3-150 4-150 5-150 6-130
So a little down on number 6 but i wouldnt have thought enough to worry about on a 20 year old car
Ive put about 10mls of oil down number 6 to try restore a little compression, spun it over, had a cuppa then refitted plugs and coils.
The car has 2 x apexi airfilters with what looks like 2 x Z32afm's (orange sticker) it also has 2 x apexi afc's fitted inside, ive got the manual but its all in japanese, would it be best to remove these afc's or whats the best setting for them?
The car seems to have a bit of white steam/smoke when running and it smells very rich , the video was taken just after refitting plugs with the oil in number 6 so some of it could be that however it did it before putting the oil down, as i said ive not been able to take the car for a good run so am i being paraniod? could it just be condensation?
It was coolish this morning with you just being able to see your breath in the air.
P.S sorry about the skip lol
From the begining:
