I OWN A NISSAN SKYLINE 3.5GT (IMPORT) 2003 UNFORTUNALELY THE CENTRAL CONSOLE HAS FROZEN, SO I CANNOT CONTROM THE A/C HEATING, FAN, REAR DEMIST, RADIO ETC CAN ANY ONE FIX THIS PLEASE? APPARANTLY THE PART THAT I NEED IS 30200-YE 0690 I'M HARROW BASED, HAPPY TO TRAVEL. MANY THANKS MIKE
Welcome to the forum, have you any other faults? as the usual culprit for causing electrical problems other than bad earths is the power distribution module .
The trouble is the 350GT uses CANbus so even the entertainment system is part of the system, you will likely need a specialist auto electrician.
Is you caps lock stuck?
NISSAN SKYLINE CONSOLE FREEZE
THANKS FOR THE REPLY. NOT SURE WHAT A CAPS LOCK IS BUT I WILL DEFO ASK
