1 - 13 of 13 Posts
Ordered some CRN grooved front discs as I received an advisory for excessive vibration under braking on my MOT and I was told the discs might be warped. Since then I've been looking for information on which way to fit them, i.e / or \ and it appears that \ is the "correct" way as it's less "aggressive" than /.
So no prizes for guessing which way my current discs are fitted. Yep, /. So the vibration could simply be cured by changing my / to \ and the discs might be fine. :spank:
Guess I should have done some research before reaching for my wallet. :Uzi:
Yeah but that wouldn't cause the wheel to wobble when breaking
It's not the wheel that wobbles, it's just very bad vibration through the brake pedal. I guess it's better to be safe than sorry though. :)
Just been reading through this guide to brake vibration and the myth of warped discs,
http://www.powerbrake.co.za/downloads/tech_01_judder.pdf
and, given the state the rest of the car was in when I bought it, I can well believe that the discs and pads were not properly bedded in after being fitted. :spank:
If the peddle is moving up and down under breaking then i'd be inclinded to do disc and pad change anyway. somethings warped
That's the plan now. I might swap the o/s and n/s discs before fitting the new ones just to check my theory about rotation direction though.
I dont understand how that can show up on a normal MOT. They only check for visible brake condition and braking force/balance as a percentage. Am I missing something, could someone explain how this can fail a Mot?
According to the MOT manual (3.7.b.1c)
http://www.ukmot.com/3-7.asp
b. Evidence of severe brake grabbing or judder as the brake is applied.
Probably best to read this first mate before deciding that \ is correct and not / :):-
http://www.skylineowners.com/forum/showthread.php?t=172741&highlight=vanes
How would you test for that on a car with ABS? don't ABS breaking systems cause the peddle to 'judder'?
abs only works when all 4 wheels are rotating and the roller brake tester doesnt activate the abs
1 - 13 of 13 Posts
