hi jamie this is the spec for a single turbo'd 610bhp one ive just sold.....
Engine: RB25
Trust 87mm Pistons
Trust Rods
RB26 Crank Lighten & balanced
N1 water pump
Nismo Bearings
Greddy Oil pump
RSP high lift inlet camshaft
RSP high lift Exhaust camshaft
RSP bigger Inlet/Exhaust valves
RSP modified head + Polished & ported
Q45 throttle body
Turbonetics Turbo
RSP oil/water feeds
RSP custom alloy pipe work
Greddy 3 row intercooler
Greddy 1.6mm Steel head gasket
Greddy stainless steel Top mount manifold
Greddy Downpipe
Greddy type R wastegate
Greddy 100mm Drag exhaust system
Greddy Type R BOV
Greddy 13 row oil cooler with relocation filter
Greddy inlet plenum
Bosch fuel pump
Nismo in-tank fuel pump
Nismo 740cc Injectors
Nismo Thermostat
RSP induction kit
AEM ecu
AEM 5 bar map sensor
Greddy Profec B boost controller
O,S Gilken triple plate clutch
this is my white gts now, it should be between 650-700 bhp
Engine :-RB26 TWIN TURBO
JE 87mm Pistons
Eagle Steel Rod Set
1.2mm RSP Steel Headgasket
N1 Oil Pump
N1 Water Pump
Trust Sump Extension
RSP Modified GTR Sump (2wd)
Tomei Cam and adjustable pulley set
RSP Turbo Manifolds
Tomei Turbo Elbows
Garrett GT2860-5 Turbos
Full Engine Balance
Nismo 280lph Fuel Pump
HKS 1000cc Injectors
Greddy Fuel Rail
Aeromotive Fuel Pressure Regulator
RSP Washer Bottle/Catch Tank
RSP 4" Intercooler
RSP Custom Intercooler pipe kit
Greddy Intake Pipe Kit
Tial Blow Off Valve
Colour Coded Cam Covers
Transmision :-
OS Giken tripple plate clutch
Nismo Short Shift
Electrical :-
AEM Engine managment with 5 bar mapsensor, Launch control and traction control enabled
Greddy Profec B Boost Controler
Greddy Remote Boost Switch
i hope that helps bud..
