1 - 10 of 10 Posts
Ok Penelope!
Hi All,
Driving to work this morning, all of a sudden the power steering went. Checked the fluid levels, look fine. Does anyone have any ideas. I think it might be the pump. Does anyone know how much they cost and how likely i am able to get one quickly.
Could be worthwhile and save some pennies.... I asked about the ecu wiring cos I once buggered up fitting a Blitz power meter to the speedo signal wire from the ecu. The result was a loss of power steering and HICAS until I sorted the wiring (ie got it the correct way round). ANything wired in to the ECU may be worth checking.
Ahh.... There's the problem. No belt! lol
Belt itslef is probably about a tenner. Fitting requires removing the radiator and a few bit and bobs.
Richard Bell is the man to speak to I believe, he stripped my rad and everything out, fitted a new water pump and rebuilt the lot in two hours. Very reasonable rates too.
I reckon it shouldn't cost you much if its just a few hours labour and a simple belt.
1 - 10 of 10 Posts
