1 - 8 of 8 Posts
hi
took the car to the garage this morning. the problem is the bearings in the pump. they also topped up the fluid which has improved the steering. options are to keep going till it gets worse and then replace the pump. so are they easy to get hold of. another option is a place in Huddersfield who recondition pumps. any ideas.
One from a 350Z should fit and i think one of the Nissan 4+4 use the same engine.
had the same problem with mine a few years back, its a common thing the bearings get worn out, I swapped the belts at the same time, got mine from conceptuatuning
thanks
conceptual look like they have a new one for 200 pounds. there is also one on ebay 2nd hand for 95 pounds
hi
since the power steering fluid was topped up the noise has gone and the steering is better. not sure if this temporary and coincidental
just see how you get on with it mate, if you don't need a new pump then there's no point in buying one, I only swapped mine because it was noisey and had worn the bearings in the pulley.
1 - 8 of 8 Posts
