1 - 1 of 1 Posts
Hey Guys,
First time posting. So my PS system had broken its main feed line and sucked up so much air it turned to foam and then blew up the front pump bearing. I rebuilt a donor pump, cleaned out reservoir, replaced all soft line joints, replaced all high pressure copper fittings, and then replaced the rear return line from rack to reservoir. I had spun pump and sent fluid through it before running it on the engine. Needles to say i have no PS. Once the car is on the ground there is zero assist. I have over and over again tried to bleed it with it the reservoir cap off. Not really any bubbles. No leaks anywhere. Seriously so sad right now.
1 - 1 of 1 Posts
