1 - 1 of 1 Posts
Now we are running a Powerflex Group buy with up to 15% off of rrp untill the end of Feburay 2011. The conditions for this group buy is,i must have 10 people to obtain the 15% discount under 10 people then i can only offer 10% discount.
2 x (PFR46- 410) Rear Diff Mounting Bush rrp £44.76
-10% discount = £40.28
15% discount =£38.04
2 x (PFF46-218) Front Lower Radius Arm To Chassis rrp £76.68
- 10% discount = £69.01
- 15% discount = £65.18
***NOTE for non GTR models
10 x (PFR46-204) Rear Link Bushes (these are non adjustable) rrp £223.80
- 10% discount = £201.42
- 15% discount = £190.23
***NOTE PFR46-204 fit all Skyline R32/R33/R34 Models exc. HICAS
2 x (PFR46-205) Rear Toe Link Inner Bush rrp £44.76
- 15% discount = £38.04
***NOTE PFR46-205 fit all Skyline R32/R33/R34 Models exc. HICAS
4 x (PFR46-203) Rear Trailing Arm Bushes rrp £89.52
- 10% discount = £80.57
- 15% discount = £76.09
The length of the bush is 45mm with a diameter of 33mm, please check original bush to confirm dimensions correct. ***NOTE PFR46-203 fit the Skyline R32 Models Only
4 x (PFR46-210) Rear Trailing Arm Bushes rrp £89.52
-10% discount = £80.57
For bushes that measure 50mm with a diameter of 31.25mm ***NOTE fit the Skyline R33/R34 models only
8 x (PFR46-204G) Rear Upper Arm Bush - Camber Adjust rrp £210.72
To replace all the rear upper arm bushes allowing camber adjustment of +/-1.5 deg. you need the following
8 x PFR46-204G rrp £210.72
2 x PFR46-204 rrp £44.76
2 x PFR46-205 rrp £44.76
Total rrp £300.24
- 10% discount = £270.22
15% discount = £255.20
Here is the link to the Powerflex web page for the Skyline http://www.powerflex.co.uk/products/Skyline+GTR+R32,+R33,+GTS-T-422/1.html which has got all the notes on it
Payment for these will be on ordering
Payment methods
1. Paypal (3% surcharch to be added)
2. Bank transfer
3. Cheque
Many Thanks
Samy
1 - 1 of 1 Posts
