fitted my blitz dv today and hard pipe in replace of the black hardpipe near the airbox, i left the recirc valve in place and re reouted the pipe from the inlet/throttle to the new blitz dv.
problem: car feels slower
sounds a fair bit louder
carnt get max boost anymore
so... i put the vacume pipe back on the standard re circ valve problem solved!! what do i do now, theres a screw on top of the blitz dv but what does that do? if it adjusts it which way do i turn it??
any help given much appreciated thankyou.
I'm bringing sexy back
I blocked up the standard recirc valve when I fitted mine, I'll get a pic up later on on how I fitted mine. My boost was a lot more stable after I fitted it. Turn the screw as if your tightning a normal one, mine is set around 15mm out
Thats the way the instructions told me to do it lol
I reckon you need to block the recirc up as even with no pipe the pressure will still open the spring on it
