1 - 20 of 21 Posts
So lads n lassies, not been on with any updates for a while with my project so I'm needing to pick some brains about my new skyline project. I have been looking out for an accident damaged/stolen recovered for my gtst project & came across this 2.5 N/A stolen recovered, usual broken window barrel & airbag dash surround & clocks ,cut alarm siren but its still running. the problem is it wont go past 2000 revs on the rev counter. Could this be a limiter because the alarm is not completely intact or throttle body ? All help greatly appreciated. Will post pics when I'm back from gym.
Discussion Starter #2
some pics
Welcome back mate :D
Afm is a good shout as it will be in limp mode
Sent from my C6603 using Tapatalk 2
Thanks Dave good to be back , I'll try it & see wot happens. Trying to get it sorted & on the road for next meet so be pretty busy for the next few weeks but it'll be great to see yours again with the yellow kit.:dogpile:
Is it fixable or do I need to buy a new 1, & does it have to be from an n/a to get it sorted?
so resoldered the afm & will be trying it later today if I'm up in time, just a quick peak at air intake is this supposed to be a blank plug?
Central Scotland Area Rep
yes its meant to be blank on the n/a and you need to block of the nitrous port as it may be drawing in non metered air
also your tps may need set from the look of that first pic
Discussion Starter #9 (Edited)
Here's a few wee pics of maf. When i was looking at the how to I noticed my board is different & there's a pin on the board that's not soldered at all, will this make any difference? it's the third pin in from the right. Also found a cut vacuum pipe behind the throttle body right where the alarm siren is mounted, they probably hit it when cutting the siren wire's.
Thanks bud, put afm back on & either its goosed completely or its something else,if anyone has a spare I can check it with I'd be much obliged. How do you set the tps wouldn't know the first thing about it? Cant find a sticky on it bud.:cheers:
Discussion Starter #12 (Edited)
yes mate any ideas? & how can you tell from a pic a wouldn't be able to see it if you pointed it out n circled it with red pen lol.
:sorry:
I have a vid of it running but not sure if I got the dash in it I'll put it up n you can have a wee look.
http://www.youtube.com/watch?v=Vyj-f3RZSnU
Discussion Starter #17
Cheers matt, hi guys someone picked up my n/a skyline from where I was storing it if anyone see's it in a scrappy or on the road can you let me know asap? my chassis no. is ecr33-000294
Discussion Starter #19
I think so mate I was storing it at the place I bought it from, & i phoned up yesterday to be told the boy released it to someone with a wagon, getting him to check cctv & going to inform police.
Someone in there will need to pay you for that mistake
1 - 20 of 21 Posts
