Hey guys!
A friend of mine asked me to post this cause he has problems with his R34 GTT and really needs help!!!
His car is quite heavily modified and going to be mapped now.
Mods: hks exhaust manifold, turbo elbow, downpipe, decat, hks cat back, hks turbo, Z32 AFM, induction kit, FMIC, bigger injectors, metal headgasket, fuel pump, splitfire coilpacks, iridium plugs, oil catch, valve springs, tomei cams (inlet&outlet), AVC-R, Power FC and everything else I forgot....
Problem:
The AVC-R is set to 1.2 bar of boost. The engine builts up boost nicely till it hits 5.000-5.500 rpm. There the boost drops down to 0.8 bar, holds it, but doesn´t rise anymore! WHAT COULD IT BE???
On the Dyno it did 390hp without mapping! Then he realised a small crack in the exhaust manifold. Welded it, put it on the Dyno again and did only 370hp - still not mapped! But boost problem didn´t change in any way after welding. He just wants to make sure that everything concerned his "hardware" is ok, before he tells the tuner to start mapping it.
Please help...:werd:
Problem:
