So heres the story so far.
Series 2 GTS-T with a Greddy FMIC, Apexi Power FC and commander plus boost controller. Car was working perfectly running really well but more power needed so time for an upgrade. Heres what's been added
GT3037R top mount turbo.
Q45 AFM
custom made 3" downpipe
Decat
3" stainless exhaust
550 cc injectors
1.6mm greddy head gasket
Tubular manifold.
Intercooler pipes reworked.
Open dumpvalve
Walbro fuel pump
New plugs
New oil
New water
Custom water and oil feeds to the turbo.
Heres the problem.
The car fired up first click but then died. I adjusted the idle screw to get it to tick over - no problem there.
When I give it a bit of gas it just seems to die and certainly wont go over 2000 rpm.
I cant find any air leaks.
Any ideas what could be wrong or do I simply need a remap first?
The other problem I found is that no water is coming through to the turbo. I can't seem to work this out either as the rad is full and the feed pipe is quite low down on the block.
I just need a bit of advice before I start pulling things apart again.
Thanks in advance
Q45 AFM
Decat
550 cc injectors
Tubular manifold.
Open dumpvalve
Walbro fuel pump
New plugs
New oil
New water
Heres the problem.
Thanks in advance
