hi
if u read the previous thread my car has been struggling to start since Wednesday but does always end up starting. took to a diagnostic center but they could not connect to the ecu. this place does a lot of work on jap cars and he tried 3 diagnostics one with obd. when disconnecting the battery there was about an inch of water under the ipdm box caused by leaves blocking the drainage hole. not sure if this water has caused the problem as the problems started after the downpours of Tuesday night. so the slip vdc off and engine light still on. car still starts but with a bit of effort. of intrest when looking for the ecu we found a Japanese flare
That is a known problem, water getting into the PDM and IPDM, and sometimes the ECU as it sits under the IPDM.
Datascan software should be able to diagnose the fault codes.
hi
mechanic seemed to think there was a problem with ecu connections possibly the loom. there was power from where diagnostics was plugged in but coudnt make a connection. he also tried that sequence pressing the accelerater 5 times.
Most decent garages that deal with Japanese cars should be able to scan for fault codes, but they do need a reader that can deal with JOBD.
