Alloy Junkie
Hey,
When setting up the Profec B, are you suppose to use the standard I/C nipple to connect the B/C Solenoid to?
Wisecobandit pointed out to me that this may not be correct (Cheers dude). The Profec instruction tell you to connect the piping from the B/C to the pipe going to the intercooler. However, the nipple that i have used is on the return pipe (to the inlet manifold).
Could this cause problems?
Has anyone else installed a B/C in this way, using the nipple on the return pipe?
M
Guest
I had a barrel of laughs with mine!
Is it a Profec B Spec 1? with the turny nobs?
Alloy Junkie
Hey,
Thanks for the pm pork, its a spec 2, but should have the same principles.
I would just like to know if putting the piping in this way can cause probs (i.e. overboosting ;))
M
Guest
:doh: I;ve got the older one!
There are 3 pipes on the new ones aren't they - mine is much simpler.... sorry :sorry: sure someone else will be better educated...
I drove around with a screw in the solenoid pipe for a week and it didn't damage anything but there was no stopping the boost lol !
Hey Nino Just found out the answer after taking a feed off the pipework between the turbo and i/c and its hasnt made a difference to the boost problem we have.
HOPE THIS MAKES SENSE TO ALL OF YOU........
The oe take off nipple to the actuator/boost solenoid (for the turbo/solenoid) is in the i/c pipe which returns to the plenum chamber.In effect the pipework is after the air has already travelled through the i/c
In the greddy profec instructions it says the correct place to take off the feed/nipple should be before the i/c
On some of the Aussie sites it is mentioned more than once about possible problems and false readings on boost gauges etc if the feed to them was taken after the i/c.
Seeing as though i have a FMIC and am using most the the oe pipework which has been extended i wanted to see if it would eliminate my problem with boost creep/high boosting.
